Tangential to a tool to check continuity between fabrics, being able to import fabric types from another fabric to a new one would cut down on set-up time.
If Copy Parcels had an option for "schema only", that would be really nice.
A decent workaround: if you run Copy Parcels with a parcel selected, it will still create a whole new parcel fabric with the entire schema, but will only copy the selected feature in, along with any associated records, lines, and points.
So just select a single parcel, run Copy Parcels, then in the new parcel fabric, delete that single feature.
