The built-in tools the Parcel Fabric uses to create / assign / retire features as they relate to records are great, but there are still a few odd cases here are there where I've got to copy and paste the GlobalID of a record into a create/retired field of one of my other features.
I will often remove and re-add my parcel fabric from the map, to make sure that I'm taking advantage of the latest updates to the built-in label classes and the like, and it would be one less thing for me to do when that happens.
Beyond the minor convenience, though, it seems to me that for such an important attribute in the Parcel Fabric, users should be able to see it. For created features, there are easy ways to display / select them and see what's associated with an active record. But it's less obvious when you're looking for retired features. Making it easier to copy out that value to use in a filter / selection statement, or to paste into relevant fields on other features, would be a good thing, I think.
Implemented as part of ArcGIS Pro 3.3
