How to COGO a Traverse in ArcGIS Pro?
6991
12-24-2018 07:03 AM
AmirBar-Maor
This video is a quick introduction to COGOing a traverse in ArcGIS Pro.
For more help and examples read the help documentation.
See previous video on GeoNet to learn how to Enable COGO on a line feature class (it's really easy).
5 Comments
BillFox
MVP Frequent Contributor
Hi Amir,
Thank you for the video demos.
Can you please provide a status update here for the related ideas listed below?
Your reply will help determine ArcPro adoption timeline in enterprise deployment with this recent poll.
ArcGIS Pro Adjust Traverse
Add full COGO functionality to ArcGIS Pro
ArcGIS Pro support for importing and exporting traverse files
-Bill
AmirBar-Maor
Hi Bill,
There are many ideas expressed on those threads, which I  have tried to some up here:
  • Ground to Grid  and basis of bearing correction have been implemented in ArcGIS Pro 2.3.
  • Polygon and line division,, including the proportioning of the misclose have been implemented with ArcGIS pro 2.3.
  • You can enter non tangent curves using the traverse overrides (see below).
  • You can perform arithmetic operations on distance units within the traverse itself.
  • COGO area will be exposed in ArcGIS Pro 2.4 as well as an parcel attribute.
  • Importing and exporting traverse files is under consideration with high likelihood to be implemented.
  • Copy parallel as well as the buffer tool can be used to offset a line.
  • Curve fillet tool has been implemented as part of ArcGIS Pro 2.3.
  • Cul de suc entry, curve calculator and other less common tools will be implemented in subsequent releases.
Amir
FYI:Kory Kramer‌, Christine Leslie
OverrideKeystrokeUse in grid fieldExample
Tangent bearing
tb or TB
Bearing
41-56-06-4tb (using quadrant bearing)
Radial bearing
rb or RB
Bearing
41-56-06rb (using quadrant bearing)
Chord bearing
cb or CB
Bearing
41-56-06cb (using quadrant bearing)
Chord length
c or C
Arc Length, Delta Angle
25.01c
Delta (central angle)
d or D
Arc Length, Chord Length
90-59-59d
Arc length
A or a
Chord Length, Delta Angle
25.01a
pkorst_coa
@AmirBar-Maor
Hello,
We appreciate the video.
Can you help with entry of this traverse using ArcGIS Pro 2.8.2?
Segment: Curve
Length: 355.26'      Radius: 7959.44'
Delta: 002°33'26"      Tangent: 177.66'
Chord: 355.23'      Course: S87° 04' 17"W
Course In: S01° 39' 00"E      Course Out: N04° 12' 26"W
"...THENCE leaving said south right of way line South 00°52' 45" East, a distance of 747.35 feet, to the northerly right of way line of roadway and the beginning of a non-tangent curve to the left from which point the radius point bears South 1°39'00" East; THENCE 355.26 feet along said northerly right of way line the arc of said curve to the left, having a radius of 7959.44 feet, through a central angle of 2°33'26" and a chord bearing of South 87°04'17" West; ..."
Thanks for any help!
AmyAndis
Hello,
To enter this into the traverse it would look like screenshot below, you will have to use the RB, radial bearing override for the non tangent curve described here:
"a non-tangent curve to the left from which point the radius point bears South 1°39'00" East"
To check this you can use the Direction Distance measure tool to verify the chord direction and distance are correct:
"Chord: 355.23'      Course: S87° 04' 17"W"
pkorst_coa
Oh. OK.  Thank you!   Will try this!
About the Author
Product Engineer @ Esri. working on Parcel Fabric and ArcGIS Pro Tasks. Education: M.Sc. Geodetic Engineering, Licensed Land Surveyor, Licensed Real Estate Appraiser, System Designer, Project Manager... Free time: family, sailing, wing foiling, windsurfing, kitesurfing, diving, hiking.
