Zoom to feature from attribute table ArcGISOnline
500
5
04-19-2019 09:55 AM
Wondering if anyone out there has discovered a way to zoom to a feature in arcgisOnline from the attribute table.  There are occasions where we are viewing data in the table and want to select a feature and zoom to it?  Note:  Sometimes these features are so small you do not see them at the scale of the map.  I am not finding anything:
https://doc.arcgis.com/en/maps-for-office/design-and-use/zoom-to-a-feature.htm
Cindy Rendl
Reply
MVP Regular Contributor
Hi Cindy,
I hope I'm understanding what you're asking, in which case there is an easy solution. When the attribute table is open in the web map, click on the triple bar icon in the top right and, when a feature is highlighted, click "Center On Selection". See screenshot:
Sometimes it seems to actually change the zoom scale for me, other times it only centers on the selection, but in that case you can just scroll in. Does that help? Alternatively, you could share the web map as a web app. In the attribute table view in a web app, there is an option to "zoom to".
-Katherine
This totally worked and is exactly what I needed, thanks, I will share with my team here.
Cindy Rendl
Reply
Glad I could help!
Reply
Hello.
Does anyone know how to do the same in a Portal for ArcGIS Map?
Reply
No worries - Found in Attributes Table Wizard
Reply
