Why wont the Help and Hint Text appear in a GeoForm
1974
08-02-2016 04:12 PM
RobertRose
Hello
I am trying to configure a GeoForm to include Help and Hint Text for some of my input variables.  Under the Field configuration in the GeoForm configuration tool, I can select the configuration button next to each of my fields and update the Help and Hint text but it does not seem to save and carry over to the working form.  I also added text for the attachment submission button and that also did not get saved.
Any suggestions?
Tags (1)
KellyGerrow
Esri Alum
Hi Robert,
When you configure the geoform app, try selecting your individual layer in step 3, Layer.
If you do this, are you able to view the hints and help text?
Kelly
KellyGerrow
Esri Alum
Can you share the app and the web map that you are using?
-Kelly
RobertRose
Sure.
Here is the link to the GeoFrom Application:
GeoForm
And I added Help and Hint text to the first two variables
And here is the link to the map I am using in the GeoForm
http://vims-wm.maps.arcgis.com/home/webmap/viewer.html?webmap=51b19e05b77c4524a1a4c448714774b6
KellyGerrow
Esri Alum
Hi Robert,
Kelly
RobertRose
That seems to have done the trick.  Thanks!
by Anonymous User
Not applicable
Hi Robert,
I just wanted to update you that I have also submitted a defect for this behavior:
BUG-000098431: Field help text and hints are not displayed if all layers are selected in step 3 of the GeoForm Builder tool.
Best,
Katie
