Why is Arcade not an option for field calculator in ArcGIS Online?
1292
12
06-05-2019 10:02 AM
PaulMcBride
New Contributor III
I am trying to do a field calculation in ArcGIS Online.  The option for Arcade or SQL is not available.  It is defaulting to SQL.
Is there a setting I'm missing?
AaronEvans
New Contributor II
same here did anyone solve this?
RachelScott
Occasional Contributor III
Having the same problem here with sync and track changes not selected.
Has anyone found a solution to this?
MaiSwasdichira
New Contributor II
Hi Rachel,
Are you using Portal or ArcGIS Online? I used Portal and I thought that the Arcade option would appear the same way as in ArcGIS Online. However, the Arcade option is not available the same way. If you use Portal, Arcade is available in ArcGIS Pro or in the Map Viewer only.  Hope this help !!
