Hello Folks,
I have some multi-part features that cross the 180 degree East West Hemisphere line on a continuous ArcGIS Pro map and I have been getting some strange results. In ArcGIS Pro I make sure the part of the multi-part feature that spans the 180 EW hemisphere line is snapped properly and they look and behave as expected. When I pan they pan correctly. When I jump in AGOL and view the webmap it also looks and behaves in Map Viewer Classic fine. In the new Map Viewer the part of the multi-part line that spans is not visible. As I have the webmap in an AGOL dashboard the cap in the feature is less than desirable. Here are three images from exactly the same WebMap.
ArcGIS Pro
AGOL Map Viewer Classic
AGOL Map Viewer
Perhaps it has something to do with spanning the 180 degree hemisphere. Any guidance or suggestions would be much appreciated.
Thank you.
GR
Can you share the layer and map?
thanks!
