Why can I see my data in a web map but not select it?
1714
7
03-24-2022 07:27 AM
GRmapper
In AGOL I can see my data in a web map but cannot pick a feature to see the popup in Map Viewer. The pop ups are configured and are enabled. Everything worked a couple days ago. Also, the same web map works fine in Map Viewer Classic. Thanks in advance.
JamesPaull2
Another strange problem that magically fixed itself at our end too. Thanks ESRI? I guess...
JoshNock1
I have noticed the same issue, it seems to have occurred following an ESRI AGOL update earlier this week
GRmapper
We’ll that’s a bit unfortunate. I assume I’ll need to replace it in my dashboard and re-do a few things. Thanks.
JamesPaull2
We are experiencing the same issue on our public facing maps. No pop-ups are working?!?
GRmapper
 The dashboard isn’t public and only the owner and our organizational share.
AlessioDiLorenzo
we have the same issue with a Map Viewer and a Dashboard based on it.
In the last few days the popups have started to behave strangely.
Until yesterday, clicking on a polygon highlighted and opened the popup of another polygon at random.
From today popups no longer open and nothing happens when you click on a polygon of the map in the MapViewer or in the Dashboard.
Is this, as it seems, a consequence of the latest update in March? If so, is esri at work to fix it?
Thank you
GRmapper
As of this morning all is back as it was. Not sure how … but all good. We didn’t touch a thing either way.
JamesPaull2
