Why am I unable to load the USGS National Map as a Basemap?
7487
11
07-12-2016 06:40 AM
MorganJohnson2
I recently signed up for a free trial of ArcGIS.  The past couple of days I have been working on mapping a site for permitting.  Yesterday, when I finally finished, almost immediately my map was compromised and the USGS National Map basemap I had been working on was "unavailable", luckily I grabbed a snapshot of the data beforehand.  I've tried logging out and refreshing and reopening my map file, but I get a series of error messages.  Wondering if there is any reason for this or if there is anything I can do to avoid reloading layers unto another basemap. Attached are the Error Messages that I have been receiving.
KellyGerrow
Esri Alum
HI Morgan,
It looks like there is an issue with the https link to this basemap but not the http.
http:
USGSTopo (MapServer)
https:
Does your organization require https?
Kelly
http://basemap.nationalmap.gov/arcgis/rest/services/USGSTopo/MapServer
KellyGerrow
Esri Alum
Hey Morgan,
Can you share a link to your webmap or the basemap item that you are adding to your web map?
-Kelly
MorganJohnson2
Hi Kelly,
This is a link to my map: https://hntbnyc.maps.arcgis.com/home/item.html?id=ce8f67dc2d2945dca2744b83b6978635
If you try to open the link in the "Map Viewer" it appears as a map of the U.S. with no layers, although notice that in the thumbnail in the map details (link I provided above) there is text (and layers).
The basemap to which I am referring is one of the basemaps provided by the program ("Basemap Gallery" --> "USGS National Map").
Morgan
TimWitt2
Hey Morgan,
Can you make your map public? I am getting prompted to log in.
tim
MorganJohnson2
Hi Tim,
Map should be public now.
Morgan
TimWitt2
Morgan,
can you also allow anonymous access in your organization settings?
Configure security settings—ArcGIS Online Help | ArcGIS
Then we should be able to see it.
Tim
MorganJohnson2
Tim,
Anonymous access is now allowed.
Morgan
KellyGerrow
Esri Alum
HI Morgan,
http:
https:
Kelly
MorganJohnson2
Kelly,
Currently only access is through https.
This is not required, however.
Morgan
MorganJohnson2
Thank you Kelly! It's fixed now.
Morgan
