When try to share item in my AGOO the menu now says Access and update capabilities
3637
08-20-2015 11:04 AM
AllisonHoff
I am an AGOO administrator and have noticed a change in the share options from My Content.
Instead of my usual group options for sharing I get two choices
Access
Does anyone else have this or know what this means?
Thanks
Alllison
EricCarroll
That is a permissions setting on how you would like to share the content. In other words, are you going to be sharing it with everyone as read only which would be Access, or are you sharing with others in your organization that should be able to make changes to the content which is the Access and Update option. Based on your selection it will then continue forward with the remainder of the wizard so that you may embed, or simply share a link.
I hope this helps.
Eric
EricCarroll
I hope this helps.
Eric
