What would happen to a Layer View if its source is changed by "re-publish"
4147
12
03-17-2021 01:07 PM
MingHome
What would happen to a Layer View if its source is changed by "re-publish" from GDB with the same items or deferent number of items?  For example previously existing item may be no longer there and new items may be added. I am wondering, what would happen in this case?
Ming
MingHome
Hi Josh,
Your reply and sample code is very helpful and saved a lot of my time.  Regarding the "to_featureclass", is there a something like "featureLayer.edit_features" to add, delete, and update features instead of overwrite the featureClass?
Regarding the GUID issue, I am going to create a new post under the topic of SDF in the python API section. I do have another string unique ID field and this GUID issue in not critical for me.
Thanks, again!
Ming
jcarlson
You're welcome!
For file-based things, you can always create a SEDF from a file-based feature class. You can perform your edits on the dataframe, then export it out once you're done. If there's a more direct way to edit a feature class via Python, I'm not familiar with it. But then, I mostly work with services in my day to day work. I suppose there's always arcpy.
- Josh Carlson
Kendall County GIS
MingHome
Thanks and will give a try today!
Ming
