What is the size of unit of measure in the fishnet mesh of a heat maps?
567
12-18-2017 12:40 PM
KatyaDiaz
Hi everyone!
I have a new question... I am doing some web maps for an story map and I find the option of represent my point layer in a heat map, I read in a blog that this option work with the Kernel Density, but I don't find information about the size of unit of measure in the fishnet mesh. Anyone know this?
Thank you in advance for your help!
Katya
DanPatterson_Retired
All units of density are expressed in terms of their linear unit...with or without scaling...
by default, a unit is selected based on the linear unit of the projection definition of the input polyline feature data or as otherwise specified in the output coordinate system environment setting.
Which means, if your coordinate system is in meters (ie projected data) then area is in meters squared.  The number of observations (N) per area unit is density, hence N per m^2.  When N gets large, then area may be scaled up to hectares or km^2 and N gets scaled down in a similar fashion..  In short... basic math and ratios rule the roost
KatyaDiaz
Understand...
Thank you so much for answering my question Dan.
Katya
