Web map filtering by current date?
11182
13
07-01-2013 04:44 AM
ToniSevenius
Hi!
I have published a feature service and a web map to ArcGIS Online that shows some point features. Every feature has a date attribute that I would like to use for filtering. The filter is easy to set for a certain date but is it possible to set the filters value for current date? So that the filters value would be dynamic.
If this is not currently possible, it is a feature that should be implemented.
Any way that I can get around this problem? The point is that I have a lot of data in one feature service but I would like to see only those that are dated for current date.
StefanUseldinger
Note: this is only available for Hosted Feature Layers (Apply filters—ArcGIS Online Help | Documentation )
KevinMayall
Occasional Contributor II
You can use this filter and put "not in the last" 1,000 days, and it is almost the same as "on or after" today.
Kevin
NicolasSoenens
New Contributor II
I found this link but I need it in the Portal.
Dynamic Date Filter
You must sign in https://www.geo-jobe.com/admin-tools/  and it's 1000$ / year.
it is too expensive for us.
If anyone has another solution to modify the Data in Json in Portal ...
Or an other solution.
I've never done it myself.
gorozcos
This is exactly that I was looking for, thank you Naomi!
