Using floating-point files in ArcGIS Online
392
08-15-2024 09:01 AM
EmanuelAgu
Hi everyone,
This is my first time here.
Could someone guide me through importing floating-point values (.flt) in ArcGIS Online? I understand I should use the Float to Raster Conversion tool, but I can't find it. The floating-point file comes together with the header (.hdr) and projection (.prj) files.
Thank you!
Laura
by MVP Regular Contributor
In Pro Right-click on Folders and add the folder containing your .flt, .hdr, and .prj files. The Float to Raster tool should be under the Analysis tab - Tools. You can search in the geoprocessing pane for the tool. You can then share it by right clicking the layer --> share --> web layer --> publish
