User defined excel file as input to a Geoprocessing Service?
2559
10-21-2015 09:46 AM
BrianVillers
New Contributor III
All,
I am working on a geoprocessing tool for Web App Builder that allows my end users to input an excel file, and the tool would plot the records on the map.  The tool works great; however, the issue I am running into is the input of the tool.  (See Image Below)  I was hoping to have a Windows Folder GUI the same as you would find when running the tool within ArcMap.
As you can see, there needs to be an easier way for my end users to input their excel file, via a GUI that opens up a directory to their files.  Is this possible? Any helps, tips, or advice is greatly appreciated.
Brian
Tags (3)
Marco_AlejandroBonilla
Thanks, that's correct, WAB Dev 1.3 works!
Dear Brian,
Did you find a workaround for the issue?
Please help!
MB
ColeAndrews
Occasional Contributor III
I believe WAB Dev Edition 1.3 provides an interface for selecting the input for GP widget-- is that what you're running? I would check but WAB Dev GP widget doesn't work if Portal/web adaptor uses IWA.
