Update a layer in arcgis online without losing custom pop ups
685
12-14-2020 09:55 AM
sdcaddsdcadd
Hi I'm pretty new to arcgis online, and have posted some zoning information that works fine, however i have a minor change to the zoning layer.  I was wondering what is the best way to do that so that the zoning layer gets updated, but i don't lose all of my custom pop ups.  Also how do i delete a layer that has been uploaded?
thanks, mike
PanGIS
From the hosted feature layer you can create a view, which is linked to the original hosted feature layer.
When you overwrite from PRO only the original will be rewritten and the view will retain all the configuration. You might need to set the view definition of the view layer if you made a change in the schema (like you added a new field)
Create hosted feature layer views—ArcGIS Online Help | Documentation
Set hosted feature layer view definition—ArcGIS Online Help | Documentation
Hosted Feature Layer Views (arcgis.com)
sdcaddsdcadd
What if I'm not using Pro but arcmap desktop? Is it basically the same process?
