Unable to save edits in new Map Viewer
782
01-05-2023 02:39 PM
FOMELC01
I am unable to save my edits in the new Map Viewer. When I delete a point, I get the message "Edits could not be saved: No permission to edit the specified feature". However, I have no problem deleting these same points in Map Viewer Classic. What is going on?
I'd like to move to using the new Map Viewer, but this is preventing my being able to use it.
MJBiazar
Hi @FOMELC01  the error seems to be happening in Map Viewer if a publicly shared hosted feature layer has the following configuration:
What access do anonymous editors (not signed in) have?
  • Only add new features, if allowed above (requires editor tracking)
As you noticed, it's only reproducible in Map Viewer and you should be able to edit the features in Map Viewer Classic as expected. Unsharing the layer with public or changing the setting for "What access do anonymous editors (not signed in) have?" to "The same as signed in editors" will also allow you to edit features in Map Viewer.
We are currently investigating this issue to determine the best next steps to address this issue.
Best,
MJ
