Hi! I have been trying to simply calculate the area of some polygons using Arcade, but the function has been running for 3 days, and I haven't got a result yet. I only see the progress page that says "Calculating Records" and shows the progress "0/96". Has anyone experienced this before? I have calculated areas in the past and never had this problem.
Anna
Are you working on hosted feature layer? What expression have you created?
Yes, I am working on a hosted feature layer, and I am using the following expression:
AreaGeodetic($feature, 'square-kilometers')
Anna.
I am also seeing the same problem. In fact, I can't calculate *ANYTHING* using Arcade, numerical or text string, and using a hosted feature layer. Last week, I submitted this problem to Esri and Tech Support created a Bug #. See attachment. The problem has not yet been fixed.
- Scott
Anna, thanks for reporting we're investigating this. I think if you use the same expression from the item page you should be able to work around the issue in the meantime.
Thanks, I'll try to do that.
Anna
Anna.
I just got off the phone/Zoom with Esri Support about this. They recommended (a) doing the calc. in the browser's incognito mode or (b) clearing the regular-mode (non-incognito) browser cache. Both allowed the Arcade calculations to work properly. I wish I didn't have to clear the Google Chrome browser cache, but it was better than not getting any results.
Hope that is helpful for you.
- Scott
Quick update on this one, this should be fixed tonight
