Unable to Modify Empty Hosted Feature Layer Attributes to Allow Nulls
1601
01-21-2021 08:08 AM
luckachi
Occasional Contributor III
Hello, I have a hosted feature layer that is currently empty as it is being developed for use with a GeoForm. I'd like to update a few of the fields to allow for null values but I am unable to do so. Is there any way to make these changes without having to delete the field every time a change needs to be made?
Using ArcGIS Pro does not work (Error 000664: Invalid input: This type of dataset is not supported. ) and updating through the REST service does not work even though it says it succeeded.
PeterKnoop
MVP Regular Contributor
I ended up using the ArcGIS API for Python, and for each field for which I needed to enable Nulls:
  • Add a new field with Null enabled, and the rest of the properties identical to the field it replaces (such as your Domains.)
  • Calculate the new field from the old field (dealing with values that you might need to change to Null, if needed.)
  • Delete the old field.
  • Rename the new field to the old field's name.
Repeat as needed for all your layers and fields for which you want to enable Null values.
PeterKnoop
I recently encountered this as well, and found this Esri Technical Support document that explained the situation.
Problem: Unable to modify the nullable property of a hosted feature service from the REST endpoint
luckachi
Peter - what would be the easiest method for republishing or overwriting a hosted feature layer - use the feature class to feature class tool? I'd prefer to not have to redo the domain values, etc as one field contains 60+ options.
PeterKnoop
luckachi
Ah, okay. Thank you - I'd probably have to go a different route only because I have zero experience with python.
I am surprised that this can't be changed right from ArcGIS Pro / REST service considering the layer has no data. 🤔
PeterKnoop
You could perform the same steps manually in Online or Enterprise via the user interface. Or, via the REST API. I had a bunch of similar layers and fields to fix, so I automated the process using an ArcGIS Notebook.
