Unable to load living atlas content - mixed content error
5379
10
02-09-2016 07:23 AM
TracySchloss
Honored Contributor
I am currently working through the DIY GeoApps course and one of the exercises requires me to use the Analysis button to load some Living Atlas content.  When I attempt to do this, I get a mixed content message.
I understand what this message is, but since this is ESRI data, and I'm using their Analysis tool to load data, I don't feel like I have any control over whether I'm loading this particular layer over http vs https.
If I try the Add Data button and select Browse Living Atlas layers, then I can successfully choose and add data this way.  However, these doesn't seem to be the same choices as I have under Analysis > Enrich Layer > Choose Living Atlas Analysis Layer.  Once I choose a layer, then I see the mixed content message in my console log.
I checked my organizational settings, but the security settings seem OK to me.   I tried checking 'use HTTPS only', but that didn't make a difference.
Tags (1)
ChrisWhitmore
Hi Tracy,
It looks like the Esri Living Atlas layers aren't switched to https in all the cases they should be (basically, if your browser is in https, all esri resources should be served to you over https as well without any additional configuration or intervention on your part). A fix for the Living Atlas layers is planned for the next update (currently scheduled for Feb 29th).
Chris
