Trouble finding option to calculate field value
1072
09-04-2024 10:06 AM
MayaFleagle
Hello ArcGIS Online Community,
I am working with data that is in decimal form that needs to be converted to whole numbers. I am following the instructions from the page Calculate field values (Map Viewer). The 5th step tells me to click on the menu in the column containing the values I want to calculate, then click the option for "Calculate field".
The problem is that I do not see an option to "Calculate field". This is what my screen looks like when I try to find this option:
I am using a 2020 MacBook Pro. Could this be an issue with the laptop? Should I try using a desktop computer? Could this be an issue with my assigned privileges?
Any suggestions for how to fix this or a different way to convert my data are much appreciated.
Thank you for your consideration,
Maya
2 Solutions
bbollin
hi @MayaFleagle you have to be the owner or admin of a dataset to calculate it. Do you have those privileges
bbollin
@MayaFleagleyes it would be the owner of the original item you derived it from. You can also contact your organization admin as well!
bbollin
MayaFleagle
Hello! Thank you for your response.
I do not believe I have those privileges. How can I identify who the owner or admin is? The dataset was extracted from a feature layer which is contained inside of a group. Would it be the owner of the feature layer or the owner of the group that could grant me the privileges?
bbollin
DakotaCasserlySLIC
Hi @bbollin, is there a specific Admin Privilege (Edit role) that would allow Org admins to permit Calculate Field to custom roles? For example, I have other Creators with custom roles and I'd like for some to utilize Calc Field in Map Viewer.
bbollin
@DakotaCasserlySLIC  thanks for this feedback. Extending the editing privileges to field calculation is something that is being evaluated for a future update. Feel free to add an idea here: https://community.esri.com/t5/arcgis-online-ideas/idb-p/arcgis-online-ideas which helps with prioritization and tracking!
