Translating WAB apps and other AGOL apps into multiple languages
1424
06-29-2021 03:18 PM
AlcoGISUser
I created an application a little over a year a go that helps people find COVID-19 related services. Only problem is that many members of our community cannot speak or read English. We've played around with google translate and changing the browser default language to Spanish, for example, but it doesn't actually change the language in the application (pop ups, titles, attribute values, etc.). Only the words in the browser frame.
Here's something LA County did:
https://survey123.arcgis.com/share/edea83eb0e6e430f8a2735d4b4d7471b
We're wondering if they had to make different versions of the app that are accessed through the links for other languages, but the app id never changes. The url appends '?lang=es&field:survey_language=Spanish' past the app id, however.
We have a request to modify our WAB developed application into six different languages.
Tags (3)
KellyHutchins
Esri Frequent Contributor
Web App Builder and the configurable apps all support many languages out of the box. By default they will use the language of the browser. So if a user has the browser language set to French all the pre-defined app text will be in French. This is things like tooltips, widget text etc.
They also support explicitly setting the language using the locale url parameter. There is an example here:
https://developers.arcgis.com/web-appbuilder/guide/xt-app-url-parameters-for-dev.htm
However your web map content like popups and any custom text you add to the app like title, description etc will not be translated. So in order to have the app text, custom text and popups localized you'd have to create different versions of the web map/app and translate that text then use the locale url param.
Tvenegas_RivCops
My department has been tasked with making our web apps translate from English to Spanish.  Can you tell me if Esri has any plans on making the process easier than creating multiple versions of the map/apps?
Also, Is there any plans on experience builder or instant app having the option?
PiyushRamdas
You use experience builder, create two web map for English and Spanish.
Define Widget localization in manifest.json and for application in \themes\default\ manifest.json
"translatedLocales": [
"en",
"el"
Create two buttons and call using links bylocale
..//XXx/App_Name/?locale=el
