Total towers in each postal code
256
04-24-2019 07:20 PM
RamS1
Hi Gurus,
I need to calculate total towers in each postal code. I already have 2 seperate layers in ArcGIS Online webmap. which analysis tool can be used for each postal code. I need tabular number.
Do i have to use ArcMap ?
I used 'near me' widget under WAB. It gives some result
Your help is much appreciated.
DerekLaw
Esri Esteemed Contributor
Hi Ram,
Based on the description of the analysis you want to do, e.g. - determine the number of towers in each postal code; you could use the Analysis tools in the ArcGIS Online Map Viewer, specifically the Aggregate Points tool.
Perform analysis—ArcGIS Online Help | ArcGIS
Hope this helps,
