Time Animation in Map Viewer
2110
03-30-2023 04:02 PM
JimWooten
Is the time animation tool available in Map Viewer?  If so, how do I activate it?  If not, when will it be available? It is available in Map Viewer Classic .  Thanks.
Jim Wooten
AndreasHall
Yes, it is available. First you need to make sure that you have time enabled layers in your map, after that you can make the map time aware.
Configure time settings (Map Viewer)—ArcGIS Online Help | Documentation
AndreasHall
JimWooten
Thanks, Andreas.  I found what I was looking for.  I appreciate the help.
JimWooten
Hi Andreas,
It doesn't work.  When I try to change the date and time settings, and save the map, the time slider date and time doesn't change on the widget.  See enclosed screen shot.  I set the start and end points for the time slider options to 03/28/2023 7:00:00 AM and 03/30/2023 10:00:00 AM, respectively but the time slider widget at the bottom of the map still shows the start date and time of 2/6/2023 7:00:00 PM and 2/6/2023 8:00:00 PM, respectively even after saving.  How do I correct the time slider widget to reflect the proper day and time?  Thanks.
AndreasHall
Could it be that there is no data in the time interval you are trying to select?
