Tile Imagery Layer Not Allowing To Style By Unique Values
2250
12
05-13-2024 01:59 PM
JustinH
We have a layer for the entire state of Colorado that we are trying to upload as a tiled imagery layer to Arcgis online. We have good luck with our other statewide layers to be able to style them as their unique value. Unfortunately, this one only allows us to either "Stretch" or "Classify". This is a categorical Raster set that classifies pixels as a specific Surface Fuel. Here is the Tile Layer that we posted (NOT THE TILED IMAGERY LAYER,  just showing a reference to what we want the tiled imagery layer to look like)... We want this to be a Tiled Imagery Layer since this gives you a little more freedom with styling/analysis etc.
I am wondering if it is because there are so many values (47) and AGOL is not allowing them to be classified by a unique value. Some others think it may be the category that is limiting AGOL because it is a long string.
Any ideas are helpful. Thanks!
JustinH
Okay.... We figured it out. We used this documentation to upload a table with the imagery layer. Though with two of us working on this, some of the options were never present and then magically appeared. Thanks @RussRoberts for your willingness to help.
RussRoberts
Esri Notable Contributor
This looks to be a tiled map service and not a tiled imagery layer. On the item you will see Tile layer and not Tiled Imagery like this one https://jsapi.maps.arcgis.com/home/item.html?id=44b8b4b7c21f4ee88b42ec6f35906af2
JustinH
Correct, we are trying to create the layer I linked above into a tiled imagery layer. Unfortunately, it is not allowing us to assign unique values to the tiled imagery layer that we did create. I did not link it above but I can. I just wanted to show how many values that we are trying to assign as unique because I feel like that is what is not working.
JustinH
If it is helpful, we can share the tiled imagery layer that is not allowing unique value symbology with you as a collab.
RussRoberts
Yup you can invite russell_jsapi into a group and I can check it out if you don't want to share it publicly.
JustinH
Okay, we invited you to our group. We have two layers that we are unable to symbolize by unique values in there.
RussRoberts
To use unique values your data will need to have a raster attribute table. When I check out the service it looks this was created without the attribute table.
The property on the service is
Has Raster Attribute Table: False
JustinH
Weird because the .tif has an attribute table but it is getting lost somewhere along the way. Any ideas?
JustinH
Update- We are still having issues with this layer. We have built and overwritten the attribute table and whenever we upload to AGOL, the attribute table is lost somewhere along the way. We tried to upload from pro but the "Create Hosted Imagery" seems to not work either. The upload just fails immediately. Any help is appreciated!
RussRoberts
Can you share that tif to a group and I can check it out.
