The ???sign in??? to ArcGIS Online is greyed out in the ArcGIS Desktop,
14103
15
06-02-2014 10:21 AM
JamalNUMAN
Legendary Contributor
I couldn???t figure out why the ???sign in??? to ArcGIS Online icon in the ArcGIS Desktop is greyed out.
[ATTACH=CONFIG]34273[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
JeffChartrand
New Contributor III
Okay where is the test connection Now set up?  ArcGis?  ArcGis Online?  or is this a browser function?
RainerSpitzer1
New Contributor III
This icon should be in your windows taskbar (next to the clock at the bottom right) if ArcMap is open. Just Right-Click on it to get the menu from my screenshot.
JeffChartrand
New Contributor III
Hi, I am shown as signed in the File Pull down menu but the ArcOnline below it is grayed out.  This is also true in the Add Data button extended choices.  I am running ArcGis 10.1 on a Windows 7 platform.  I suspec t our network firewall may be blocking the attempt.  I do not have the test connection in the lower right taskbar tray.
Thanks for the help, I suspect I will have to visit our resident IT team and let them sort it out.
Cheers
Jeff Chartrand
stefanstamenov
Occasional Contributor III
This is strange
AsrujitSengupta
Regular Contributor III
Please check this other thread and the links suggested there:
ArcGIS Desktop won't connect to ArcGIS Online
AndresCastillo
MVP Regular Contributor
For me, the issue of sign in to ArcGIS Online only happened in Qa and Prod Servers.
The dev server was fine.
Turns out ArcGIS Administrator>Advanced>Manage Portal Connections was only pointing to http://www.arcgis.com/
So, I added AND connected https://www.arcgis.com/ and it worked.
Add the ArcGIS Online organizational domain in ArcGIS Administrator
https://support.esri.com/en/technical-article/000013176
Maybe the server internet options/proxy whitelist only allowed https arcgis urls in the higher environments (qa/prod) to be more secure.
I also added the appropriate Esri urls to the trusted sites.
These other resources also helped:
https://esribelux.com/helpdeskitem/troubleshooting-issues-adding-arcgis-online-basemaps-to-arcmap/
https://support.esri.com/en/technical-article/000013300
https://community.esri.com/t5/developers-questions/web-appbuilder-login-issue-using-internet-explore...
https://community.esri.com/t5/arcgis-pro-questions/unable-to-establish-connection-to-https-portal-do...
https://support.esri.com/en/technical-article/000011622
