The estimated amount of credits exceeds the amount available for the organization,
5657
7
08-31-2013 09:14 AM
JamalNUMAN
Legendary Contributor
The estimated amount of credits exceeds the amount available for the organization by 7.5%,
I wanted to publish an mxd file that contains only one feature class but I got the message below
�??The estimated amount of credits exceeds the amount available for the organization by 7.5%�?�
[ATTACH=CONFIG]27138[/ATTACH], [ATTACH=CONFIG]27139[/ATTACH], [ATTACH=CONFIG]27140[/ATTACH]
What is the maximum size allowable for publishing through the ArcGIS online?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: mboeringa2010
What Uses Service Credits?
ArcGIS Online - Service Credits Estimator
Google is your best friend, after me... ;);)
And maybe the user discussion here is of some use, scroll down on that page to see the comments (although some of it may be dated as it is one year old...):
http://spatiallyadjusted.com/2012/06/15/arcgis-online-service-credits-might-not-be-a-good-deal/
AkosKisreti1
The problem here is not the size of your feature class. In your example, you tried to publish a hosted tiled service, which means AGOL generates tiles for faster display. Generating tiles are very expensive (in credits), so it is recommended to use tile services only if you have large amount of data (features and vertices).
Instead of tile services you can use hosted feature services.
There is another way to create and publish tile services. For this you have to create tile packages in ArcGIS for Desktop and upload it to your AGOL account. In this case you don't use AGOL resources to create tiles, but your ArcGIS for Desktop.
To enable this option do the following:
- Go to Customize > ArcMap Options > Sharing
- Check the box next to "Enable ArcGIS Runtime Tools"
- Click OK
- Go to File > Share as > Tile Package
In the Tile Format box you have the opportunity to adjust the minimum scale.
After you uploaded the tile package (tpk) to your AGOL account, go to item properties in My Content and click on Publish.
I hope this could help.
Regards,
Akos
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
- Click OK
Regards,
Akos
Many thanks Ákos for the help,
What is weird is that it works with no additional settings. I could add services and publish data with no problem.
[ATTACH=CONFIG]27834[/ATTACH], [ATTACH=CONFIG]27835[/ATTACH], [ATTACH=CONFIG]27836[/ATTACH]
Best
Jamal
AkosKisreti1
Hi Jamal,
Actually, based on your second and third screenshot you are using ArcGIS for Server instead of ArcGIS Online.
Akos
by Anonymous User
Not applicable
Hi Jamal,
Akos
Sorry Akos about the confusion. I just attached the wrong screenshots
Here you go one integrated example for publishing by ArcGIS Online Successfully.
[ATTACH=CONFIG]27841[/ATTACH], [ATTACH=CONFIG]27842[/ATTACH], [ATTACH=CONFIG]27843[/ATTACH], [ATTACH=CONFIG]27844[/ATTACH], [ATTACH=CONFIG]27845[/ATTACH]
The link is
http://bit.ly/1axKsr8
thank you
best
Jamal
AkosKisreti1
Hi Jamal,
Yes, I can see it now. You did not get an error message because the dataset you created the tiles for was small
If you have a large dataset or a large extent, it requires a lot of credits. For that case I recommend the tile packages that I mentioned earlier.
You can check the credits the tile creation consumed if you click on "View Status" (Its on the right on "My organization" page)
Regards,
Akos
by Anonymous User
Not applicable
Hi Jamal,
Regards,
Akos
Thank you very much Akos for the prompt answers and useful comments.
I still have 198 credits but unfortunately my trail subscription expires tomorrow.
[ATTACH=CONFIG]27849[/ATTACH]
Best
Jamal
