Symbology only gets updated on the Map, not on the Feature Service
2103
10
12-19-2022 05:42 AM
maglourenco1
Greetings everyone.
So I have the following problem: I set a Feature Service in my ArcGIS Online account. I tried to change the symbology of a sublayer in the Map Viewer and set an Arcade expression (as seen in next pic).
I then saved the sublayer (I expected) to save the new symbology on the Feature Service,
To my surprise, after I tried to open the sublayer of the Feature Service in the Map Viewer, I still saw the old symbology.
I really don't know how to effectively change the sublayer's symbology of a Feature Service. When I try to add the Feature Service to a new map, indeed the symbology has changed but the sublayer in the Feature Service itself, still has the old symbology!
Thank you very much,
Cheers
RussRoberts
Esri Notable Contributor
The Map Viewer in app and vis tab will not write back to the feature service and only use the item. You could update the feature service definition to use the new arcade editor if you are familiar with that process.
RhettZufelt
MVP Notable Contributor
Changing the symbology in the map and saving it only save symbology for that map.
If yo want to change the default symbology (the symbology when you add to new map viewer), you go to the item details page, visualization, set symbology and Save (in upper left).
R_
maglourenco1
Thank you both for your answers!
There is a problem with this solution - when I try to edit the symbology with an Arcade expression, I got the following error.
Previously I switched to the Map Viewer Classic as a workaround (that some people suggested in the past), but in this case I can't!
Anything I can do in this context?
RussRoberts
Is this an empty feature layer? If so we have a fix coming  that planned for the next release for that.  You could add a temporary feature to get around that.
maglourenco1
thank you for the answer.
I tried to create a feature as you suggested.
It is quite strange because when I try to open the Feature Service, the symbology is definitely updated as you can see here
But when I try to open the sublayer, it still has the old symbology.
This is critical for me because I intend to use the Feature Service in an app I'm currently developing for Android using ArcGIS's SDK. In case I can't in this way, the only alternative I know is to use the ArcGIS Pro software to publish a new Feature Service (but I would love to avoid the hurdle of setting a new Feature Service 😊)
Cheers
RussRoberts
maglourenco1
Thank you for your help.
In this case I need to create a new Feature Service definition in ArcGIS Pro and set the new symbology there.
Do you know if the icons available there are the same as the ones in ArcGIS Online, or other icons are available?
RussRoberts
most are there. if not you can add ArcGIS Online web styles to your Pro Project under the Catalog view > Styles > Add Style and search ArcGIS Online.
maglourenco1
Thank you for your great help!
Cheers
maglourenco1
Unfortunately it did not work 😐
I did as you said and edit the symbology in the Feature Service sublayer Visualization tab
After trying to open the sublayer
The symbology hasn't been updated..!
