Symbology in ArcGIS Pro vs. ArcGIS Online
353
03-28-2018 12:24 PM
AndrewZolnai
See attached screenshots, rotated symbology doesn't seem to be honoured in AGOL.
I submitted same re: Antarctic project under WebScene. Then I thought this was because I re-projected WGS84 into Polar Azimuthal on-the-fly. So for its Arctic mirror, I re-projected everything to Alaska Polar, to match the Arctic Ocean base-map. But I still get all arrows pointing N in AGOL, posted, whereas they point in wind direction in ArcGIS Pro, package also posted. Anyone have this problem, &/or a solution? I tooled around and haven't found one yet...
AGOL: https://arcg.is/1z9D9L
Package: https://bit.ly/2GjKBoi
AndrewZolnai
Indeed see my reply to my original  :)
SteveCole
When I look at the data, its rotating based on the PROBWINDDD field. That field is a string field. Maybe AGOL requires that to be a numeric field?..
AndrewZolnai
AndrewZolnai
Resolved - my data source was local shape-file save off WFS, which made all feature attributes text! Attribute-driven symbol styling worked in ArcMap but not when posted in AGOL or WebScene. A correct result is posted here on CLIWOC Arctic.
