Symbology for Hosted Feature Layers Removed
1317
11-08-2023 07:04 AM
CarsonG
I had symbology that was designed in ArcPro and uploaded to AGOL through a hosted feature service that has now been wiped out in AGOL. This symbology has been working without issue for about a year and a half now without issue for other hosted feature services.
The following is what the symbology used to look like. The original map in AGOL is retaining the symbology.
However, the visualization page for the same layer now only displays a single grey line.
When adding the hosted feature layer to a new map it is also not honoring the symbology that was originally set.
This specific hosted feature service was put on AGOL at the end of September 2023. I am not sure when AGOL wiped out the symbology as I am noticing it today, but I suspect the recent update may be the reason.
ChristopherCounsell
MVP Frequent Contributor
We haven't seen this experience and I don't see why the update would have done this. The other layers in your map also appear to be fine.
What would cause this is if someone was configuring the layer in the map and hit the 'reset to source layer properties' in the information > manage layer properties settings. Or if the layer was removed then re-added.
CarsonG
All point layers are fine. Some line layers are also fine. Random line layers, 9 out of 16, had their symbology wiped out.
No one besides myself edits the properties of the maps or properties of services.
The map which utilizes the layers in AGOL, has not been updated since it was created, with the exception of edits to data occurring which would not result in a change to the map/layer properties itself.
The source layer properties (symbology) were sent to AGOL in the hosted service, they were not created in AGOL so the original symbology should be the 'default' properties. The option to reset is not available because they are already referenced to source layer.
The layers affected could not have been removed and then re-added without me knowing about it. Outside I and admins, only two other people have the ability to do something like this and they would not do this.
ChristopherCounsell
Interesting. Did you publish it from Pro? What happens if you go to publish
and analyse the service?
Maybe there was an incompatibility with the symbology that got downgraded.
Sometimes these things can exist until a point.
CarsonG
It was published from Pro. No issues/errors occur when publishing as a web layer or web map.
The symbology has been in use for over a year in multiple hosted services without compatibility issues, ever since AGOL/Field Maps was updated to allow for more complex vector line symbology. I published a test service and no issues.
A previous service with the same symbology also on AGOL at the same time as the service in question, did not have its symbology altered. At a loss on this.
ChristopherCounsell
When publishing, hit the 'analyze' button. It will show warnings - things that will generate issues but not prevent you from publishing. If you have the original layer in pro with the symbology and do this it may explain why the symbology is being dropped.
https://community.esri.com/t5/arcgis-online-questions/maps-uploaded-from-pro-losing-symbology-colors...
https://community.esri.com/t5/arcgis-online-questions/arcgis-web-app-not-honouring-web-map-symbology...
https://community.esri.com/t5/arcgis-online-questions/symbology-missing-for-a-layer-in-map-viewer/td...
There are cases where symbology has been lost due to compatibility issues. Things like incompatibility don't always manifest in issues. e.g. you can publish a field with more than 30 characters in the fieldname, or certain reserved words, and only have an issue when downloading to a sqlite database (field maps).
Like you I'd generally expect these to manifest on or immediately after publishing but maybe something was there that eventually got triggered by an update.
Otherwise the only thing I can think of is that the layer got updated. But given what you described it doesn't sound like the case.
I'm not aware of any other instances where this behavior has occurred, and given it's already happened, it's going to be difficult to retroactively investigate for the community and probably even technical support unless there's a clearer answer.
