Switch side's of side car in storymaps next gen?
1024
07-24-2019 07:01 PM
by Anonymous User
Not applicable
I'm wanting to know how to switch the way the sidecar displays or the small photo in the next gen story maps. So it's like this instead of the standard - this is an ESRI example so I know it can be done
And then if you can add paragraph text to the left side of a photo instead of the default to the right. (not in a sidecar).
Thanks in advance for your help.
ShelleySchott
Hi Kate Waterhouse‌,
I am fairly certain that a sidecar was used to achieve this affect.
With the sidecars you can change the position of the text to either side of the main image using the switch panel placement option. https://doc.arcgis.com/en/arcgis-storymaps/author-and-share/add-sidecars.htm
What you can do is to have only 1 sidecar with that section, that will remove those anchor points which are seen when more sidecars are configured.
Shelley Schott
Senior Consultant, Esri Australia
