Is there a way to sort the dropdown list alphabetically in the Filter widget in Web AppBuilder? It seems to be a random sort, which is challenging for a user. I have "Ask for values" checked to prompt a user of the app to set their own filter, and the filter is set to Unique. This populates the dropdown list, but in no particular order. I'd love it to sort alphabetically or allow for a default sort to be set.
Thank you.
Just for reference you can see the details for the defect here:
BUG-000099321: The Filter widget does not sort alphanumeric values ..
Hi Jessie,
Do you have this application shared publicly? I just set up a filter with the following settings:
When I use the Filter widget it does appear to sort those values alphabetically:
Do these settings match with what you have configured?
Katie
Here is a link to the app: http://utah.maps.arcgis.com/apps/webappviewer/index.html?id=7723c9bb92e9442b8794a6bdad73d01f.
My settings look the same as yours. I wonder what is different about your dataset?
I would like to get a Support case created to take a look at this, I will send you a message.
Thank you,
Katie
Hi Jessie,
We've identified a bug with sorting alphanumeric values properly in the Filter widget. We have a planned fixed for the next ArcGIS Online update (scheduled for Dec).
Hope this helps,
