Simple way to export a Layer List for a Web Map to Text
773
7
05-25-2017 09:47 AM
BrianO_keefe
Regular Contributor II
Is there a simple way to export the layer list from a web map (built with WAB) to a text file?
Lake_Worth_BeachAdmin
open the feature service in arcmap (in catalog you will see an option for feature services, then use arcpy to list the layers
LindsyHales_Bentley
Is there a way to do this for all services at once? Thanks!
JoshuaSharp-Heward
Do you have access to ArcGIS Pro or ArcGIS Notebook (in AGOL or enterprise)? If so this can be done using the ArcGIS API for Python pretty easily!
LindsyHales_Bentley
Yes, I have both of those.  Any help is appreciated!! Thank you!
JoshuaSharp-Heward
Easy then!
from arcgis.gis import GIS
from arcgis.mapping import WebMap
gis = GIS('pro')# if running this from Notebook for ArcGIS in AGOL/Enterprise, replace this line with gis = GIS('home')
wmItemId = "" #put the id of the webmap in here
wmItem = gis.content.get(wmItemId)
wm = WebMap(wmItem)
for lyr in wm.layers:
print(lyr.title)
I wrote that to be run from the Python window in Pro, but see my note in line 3 about using it in ArcGIS Notebook. Just put the ID of the web map item into line 4 and it should print out all the layers for the given webmap.
LindsyHales_Bentley
Thank you so much!!
JoshuaSharp-Heward
Glad to help out!
