Show percentages in pop-up chart?
2650
02-29-2016 01:41 PM
by Anonymous User
Not applicable
Hi all, is there a way to show percentages rather than counts in a pop-up pie chart on ArcGIS Online? I initially had fields for each category's total counts, but added new fields that show the percentage instead. However, I cannot add a "%" symbol to the end, as otherwise it gets formatted as string and thus can't be incorporated into a pie chart. As a result, when you scroll over the pie chart, it's not immediately clear that the numbers are percentages and not counts. I've attached a screenshot; the box outlined in red is what appears when a user scrolls over the pie chart. Is there a way to add a "%" symbol to the end of "50"?
I've read through these posts but haven't found anything specifically addressing this issue.
43756 - Percentage value is not reflected in ArcGIS Online charts and pop-up windows
Configure pop-ups—ArcGIS Online Help | ArcGIS
Any help is greatly appreciated, thanks!
RebeccaStrauch__GISP
by Anonymous User
Not applicable
whoops thanks! for some reason my question posted twice.
I had the same thing happen this weekend.  Hit add reply...nothing happened.  Kept trying finally giving up.  Went back in and it was there about 6x.
