Related records don't display in new Map Viewer but do in old Map Viewer
26660
61
02-07-2022 07:13 AM
luckachi
I am trying to figure out why one of my web maps is unable to access the related table. When I open the webmap in the old map viewer, I see the "Show Related Records" at the bottom of the popup, however, when I open the same webmap in the new map viewer this does not exist.
I do have another webmap that contains a layer with a related table and it works just fine with the new map viewer.
I would really like to avoid re-creating the table/layers/relationship...
User35489
In my case, after upgrading ArcGIS Enterprise from 10.9 to 11.1, the related records disappeared, when I tried to view from Map Viewer.
The in-memory relate was made on a column with integer data type. When I changed(the whole process of transforming field) the relate field's data type from integer to text, the related records appeared again.
Hope this will help someone struck with a similar case.
JamesFotyAPD
I'm surprised that this feature still has not been rolled out for Enterprise Portal or for non-hosted feature layers in AGOL. Some of the functionality is already included in dashboards and Experience Builder, which allow for custom relates based on a single field. Functionality like that in the map viewer would be pretty cool.
bsanders69
I am going to be cautiously optimistic here...  In the ArcGIS Enterprise 11.2 Issues Addressed List document there are actual Enhancements for Editing related records (ex:ENH-000162552 Provide ability to edit related records for feature-to-table relationships in the Map Viewer.)
Kevin_MacLeod
I can confirm, it still doesn't work in 2024.  I'm going the Classic Map Viewer route.   It is hard to understate the importance of relates; every Big Customer uses them for inspections. For many Big Customers, data will remain on SDE in SQL Server. SDE/SQL can do a lot that AGOL/Portal can't, by design. (SQL views, granular security management)  There are various reasons to keep things out of Portal federation. Server/Enterprise/ProductName and SDE are where Big Customers store Important Data.  'Classic stack' stand-alone server, classic map viewer, WebApp Builder, ArcMap often provide mission-critical capability like relates that new Map Viewer, Portal, ExpB, Pro lack.  I know they'll get there but I'll inquire on this at Dev Conf with product teams.  edit: I added to classic map viewer and my inspection app was up and running in WebApp Builder and Field Maps in under a minute for real. I understand MVC in ExpB and 3D/VR/ probably AI soon in the JSAPI 4 but the old stuff provides capability; just works, and the interface is efficient and intuitive.  TL;DR:  use classic map viewer for now.
Miralem_Zeljo
I hope Esri will do something about this and make relationship tables easier to manage in new maps/applications. It would be great if they would allow data joins and table edits inside table widget.
AnneTetley
Could really do with this being fixed.  I'm a big fan of the new map viewer and would love to leave classic behind...  hope its included in 11.2.
MetralAlexis
I there, I had a similar issue explained in that post. Using a Feature Service instead of a Map Service brings the related tables and it's possible to add the related records in the Popup. However, it's not practical at all, you can see the related records one by one only and there is no "Show related records" option to automatically open the related table filtered with the related records of the selected feature.
StormwaterEngineer
Not sure if anyone has posted a solution to this, but I was running into the same issue. The way I found to fix the issue is to open up your table in the new map viewer and click on enable pop-ups. You can select the fields you want as part of the pop up then these will show the information under the layer related records.
msa401208
I enabled the pop up for Table and still not seeing Related Records option when I clicked on the map polygon feature? Is it possible to capture a video of how you got it done please?
JackHardwick4
Just got off a Chat with Support. Still saying only Hosted data supports showing related records. Referenced data with related records works in Classic Map Viewer but that's only available in AGOL until Q1 2026..
I'm really tired of seeing Esri blog posts saying, "Rolling out Related Records" when they only mean for Hosted content.. it always gets my hopes up..
My organization is probably going to do some sort of Arcade workflow to accommodate or just use the classic viewer for this map while we can.
