"Update View" Option Not Showing
225
04-18-2022 03:14 PM
MaggieMartinez
I am trying to update the view layer of a hosted feature layer, but no "Update View" button even shows within the settings tab of the view layer.
I did not set up these layers so I am unsure how it was created, but I am sure the view was created from the hosted feature layer I made edits to. Any ideas on why the update view button would be completely absent here?
Thanks!
Tags (3)
jcarlson
Per the AGOL docs:
Only the owner of a hosted feature layer can create a hosted feature layer view from the original layer.
I have to assume the same restriction applies to any adjustments made to the view, though the docs are not as clear on that point.
- Josh Carlson
Kendall County GIS
ToddFagin
Occasional Contributor II
Were you able to resolve this? I have the same issue. And this persists whether or not I am logged in as the owner of an item or just as an administrator.
