Publishing a Raster to ArcGIS Online?
28996
04-30-2019 07:16 AM
EvanStern
Hello,
I want to be able to publish this map to my AGOL account, but the raster doesn't come through (the preview shows this) (pictures attached). Can this be done?
KellyGerrow
Esri Alum
Are you trying to us the raster data as visualization or as an image service, so that you can access imagery data and perform analysis?
ArcGIS Online currently does not support image services. If you want to have web access to imagery data, you will need to publish to ArcGIS Enterprise: https://enterprise.arcgis.com/en/server/latest/get-started/windows/what-is-arcgis-image-server-.htm
If you are looking to use the raster data for visualization only like a basemap and do not need access to the underlying data, then I would encourage that you publish a tile service: https://doc.arcgis.com/en/arcgis-online/manage-data/publish-tiles.htm. Note you will not be able to change the visualizations of the data unless you republish if choosing this method.
-Kelly
KellyGerrow
Esri Alum
-Kelly
Ed_
by MVP Regular Contributor
any update on this @KellyGerrow ? Are their plans to be able to publish rasters an image service where you can visualize change symbology and etc.? it's a real limitation to be able to publish rasters as a basemap and nothing more.
Question | Analyze | Visualize
