problem of creating Distance to Road Map with Euclidean method
713
02-03-2022 09:29 AM
oyashimandana
every time i want to process Euclidean distance operation in Arc Gis ..i came up with an error message ...can anyone help me ...
DanPatterson
MVP Esteemed Contributor
they are warnings, what was the error message?
Was any output created?
Are your data in projected coordinates?
Your F: drive is that a local drive or a usb stick?  Also, spaces in paths are not recommended,
... sort of retired...
oyashimandana
thank you for your valuable feedback
yes it created an output file ...
still, i getting this error message
yes, I have converted all my data into a proper projected coordinate system...WGS 1984 UTM 45N zone in my case
My F drive is a Local drive, not USB stick
DanPatterson
it is a warning, not an error, some of you locations are on masked cells and they won't be processed.
I don't know where those locations are but they are excluded from being processed, you will have to remove the "mask" or exclusion area
