Printing Issue from ArcGIS Online  Map Application
21927
38
04-24-2012 08:29 AM
IT_DeptDept
Hello everyone,
I created a map application using ArcGIS Online template ( Basic Viewer) which has printing functionality. But print is not working. I thought of browser issue and tried to print in different browser, still no luck. Here is URL for map application;
http://www.arcgis.com/apps/OnePane/basicviewer/index.html?appid=9acad5c2f1e3447fbee1472c795b0847
One more question, is there way to make "Details" tab as a default instead " Legend" in Basic Viewer template?
Thanks
MikeMinami
Esri Notable Contributor
I can reproduce the problem with your application. We are looking into it.
Mike
IT_DeptDept
That would be great help !
Thanks Mike.
CharlieHofmann
Any luck in setting the "Details" tab to be the default in the Basic Viewer?
I've downloaded the template and spent some time looking through the code, but really don't know where to start when it comes to customizing that.
Thanks!
Charlie
KellyHutchins
Charlie,
The easiest way to make the detail panel the default is to find the following code snippet (~ line 630 of layout.js)
  if (configOptions.displaylegend == 'true' || configOptions.displaylegend === true) {
    addLegend(layerInfo);
and move them to approx line 598 - just above the code that adds the details button and panel
<!-- ADD LEGEND CODE HERE -->
  //Add the Detail button and panel
  if ((configOptions.displaydetails === 'true' || configOptions.displaydetails === true) && configOptions.description !== "") {
KellyHutchins
The printing problem is a bug that will be fixed in the next release.
Kelly
JayLarsen
I can see no improvement in AGOL printing.
ZIP layers disappear.  Other feature layers either disappear or print with a generic "blank icon" instead of they symbol.
How can I escalate this printing discussion?  This has been going on for at least a year now.  New releases are always promised, but I can detect no change.  Whether Firefox, Chrome, or IE...Mac or Win.
CharlieHofmann
Kelly,
It worked like a charm! Thank you!
Charlie
IT_DeptDept
Thanks Kelly,
Line placement of code was really helpful to set a default tab. Now, my question is how one can showcase the customized map apps into Public Map Gallery 1.3.1.
Regards
MichaelKlein
Kelly
Hi.  I'd like to use the Printing functionality also.  I'll keep watching this tread for news of the next release with a working Printing button.
Thanks.
