Print Legend Symbology not rendering properly in 10.1
3364
11-05-2012 12:59 PM
AnnaLambrechtsen
when i print with a layer added to the ESRI javascript API from AGS Online, whether i'm using the standard PrintTask or a geoprocessing task added to arcgis server, the legend symbol is not right for the AGS Online feature layer.
the attached image illustrates this.
left hand side is generated by:
publishing a print geoprocessing task through AGS and consumed using the javascript API PrintTask:
http://[AGS 10.1 server]/arcgis/rest/services/[map service]/GPServer/[print GP item]
right hand side is generated by:
using the 10.1 print tools:
http://[AGS 10.1 server]/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task
using the javascript api the map is setup with the following layers:
  1. open street map base map
  2. dynamic map service with 3 layers - do not render properly in legend
  3. AGS online feature layer - does not render properly in legend
  4. feature layer based on layer in dynamic map service in 2 - renders properly in legend
