Prepare and publish data arc gis online
1088
10-06-2019 04:29 AM
FionaMelville
Do I need to use arc gis pro or desktop to prepare and publish data to a webmap for use in the collector app or can this be done solely in arc gis online?
by Anonymous User
Not applicable
Hi Fiona,
You may not require desktop or pro if your data is in the following format. You can just use ArcGis Online to publish your data.
Comma-separated values (CSV) files that contain coordinates or addresses
Microsoft Excel files (.xlsx or .xls) that contain coordinates or addresses
Google Sheets on Google Drive
GeoJSON files or zipped shapefiles
Feature collections
Zipped file geodatabases
Zipped collections of georeferenced photos (photos with locations)
A template or existing feature layer
Publish hosted feature layers—ArcGIS Online Help | Documentation
by Anonymous User
Not applicable
Hi Fiona,
Feature collections
FionaMelville
Hi, I had no problem uploading a csv file as a hosted standalone table and was able to generate a list from the attributes listed in my table (domains) in ArcGIS Online. However, I really want this table as a hosted feature layer for use with Collector App and I do not want to add each domain individually. So I uploaded the same .csv table as a feature layer but when I try to generate a list of domains I get an error message saying There are no values in this field to generate the list. Any advice much appreciated.
hello Fayaz thank you for original reply which I have just seen, my apologies. I have just posted the above query related to arc gis online and wonder if you can also help here? Thank you.
