Portal for ArcGIS & World Geocoding Service
3804
03-11-2014 05:54 AM
ErnestoCarreras3
Can somebody answer me the following question: If my organization decides to implement Portal for ArcGIS to keep our entire data in-house, can we still leverage the World Geocoding Service? Can this service be leverage through the Data Appliance for ArcGIS?
DerekLaw
Esri Esteemed Contributor
Hi Ernesto,
Yes, Portal for ArcGIS is preconfigured to use the World geocode service hosted in ArcGIS Online (be default), or you can use your own locator service. Learn more in this help topic: About utility services
The ArcGIS Data Appliance includes a World Places Locator - which you could publish and enable in your own ArcGIS Server site.
FYI, ArcGIS Data Appliance whitepaper. Is that what you are asking?
Hope this helps,
PaulHardin
I agree with Derek's answer.  However, there is something you need to consider as we have run into it in our organization.  Portal is inside our firewall and on our intranet network.  We have no issue accessing this from any computer connected to our network at our locations.  However, if you're planning on using Portal on mobile devices (i.e. IOS, Android, tablets, or laptops) in the field you need to consider whether your VPN allows access to ArcGIS Online servers and map services.  In our instance, our IT Security group will definitely not allow opening up our VPN tunneling to include the whole range of Esri's Amazon Cloud servers IP ranges.  So therefore, we had to create any geocoding/locator services and basemaps served by our own internal ArcGIS Server which is allowed access through VPN.
I hope this helps.
Sincerely,
Paul Hardin
Senior GIS Specialist
Nashville Electric Service
ErnestoCarreras3
Thanks for your responses. They all have been helpful.
