Pop-ups not displaying in Field Maps
2875
11
01-09-2024 11:48 AM
MarcRabideau
Hello, I am having a problem where my pop-ups are displaying fine in web viewer, but when I open the map in FieldMaps they are not coming up.  Has anyone experienced this? Any advice on what might be causing this issue?
EmilyGeo
Hi @MarcRabideau
Are you using Map Viewer to set up the map for use in Field Maps? If so, can you check to make sure that pop-ups are enabled for each of the layers that you want to have a pop-up appear on the map?
  1. With the layer selected in the pane on the left,
  2. click Pop-ups on the toolbar on the right
  3. ensure that the Enable pop-ups toggle is switched to on (blue)
MarcRabideau
We are using the classic map viewer, definitely have my popups enabled for all the layers.  We have a couple layers where the popups are working in field maps, but the majority are not.
EmilyGeo
I'm not sure why this is happening, I haven't heard of this before.
I'm interested in hearing if there are specific reasons you are using Map Viewer classic?
The newer version of Map Viewer actually treats pop-ups and forms separately, so the resulting behavior in Field maps could be different.
For the sake of troubleshooting, would you be able to save a copy of the map in Map Viewer, confirm that pop-ups are enabled there, and then have a look at that map and see if its working in Field maps?
MarcRabideau
I am not seeing how to open with the new map viewer from our portal, is there a required version we need to be running?  We have the new map viewer in AGOL, but I dont see the option in our enterprise portal.
SantanaClement
I am experiencing the same issue in my Field maps. I checked the Enable popup for my layers and they are all enabled. I can see the info in a web mapping application just not in Field Maps
Katelyn1
I am also experiencing this issue in Field Maps, while using Enterprise 10.9.1. Was anyone able to find a resolution?
Jessica_S
Hi!
What environment are you in (ArcGIS Online, Portal for Enterprise, etc.)?
Is editing enabled on the affected layer(s)? What is the sharing level?
Have you configured pop-ups in Field Maps Designer?
Where was the layer created? If it was in ArcGIS Pro, can you test by republishing the layer to Online, then adding it to the map? You may have to reconfigure pop-ups in Map Viewer, as sometimes they're not automatically configured.
LeahMontoya
Hello,
We are experiencing the same issue.  We are now on Portal Enterprise 11.3.
The layer is not editable and shared to the public through our Portal.  We have configured popups in Pro and published.  We use Map Viewer to create the map (this map has never been used in Classic Map).  Popups in Field Maps will not work on this feature.  When we build a map with this same layer used in Experience Builder, Webmap Builder or Instance Apps the popups work.
The popups worked before when we was n 10.9.1.
Thanks
Jessica_S
Hi @LeahMontoya! To clarify, are the pop-ups working correctly in Map Viewer and the problem is only in Field Maps?
Have you already tried republishing the layer to your Enterprise portal, from ArcGIS Pro?
Also, are you receiving any errors when accessing the list of layers?
