pop-up shows the code of the domains instead of showing the description
988
03-02-2022 06:06 AM
HalaAbdelmaksoud
Hi all,
an issue occurs after selecting a feature in info summary widget: the Pop-up shows the code of the domains instead of showing the description.  How to fix this issue ?
Considering that this issue occurs when using a published spatial view on the other side, it works well with a feature layer.
ABishop
MVP Regular Contributor
Hello Hala,
Its not best practice to use views as published feature services.  I have seen many limitations with this practice in the past.  Also, with coded domains, you can use the description as the code or build an Arcade expression to mask the coded domain in the pop-up.
Amanda Bishop, GISP
BillFox
MVP Frequent Contributor
or use the same value for the code and description - depending on the type of domain it is
