Polygon Labels do not appear in Web Map
725
05-01-2021 07:54 PM
Labels (3)
THayes2000
New Contributor II
Any reason why the Labels for polygons will not appear in a Web Map? Here is a screenshot, the white circles I drew on the screen capture and are where the label for each polygon should appear. The polygons are the semi-transparent gray areas.
Tags (3)
THayes2000
New Contributor II
I had a brain **bleep**. I was using the map image layer not feature layer. It works now.
I have to pay closer attention next time.
JayantaPoddar
MVP Esteemed Contributor
Could you check if
1. Values are available in "Official Name" attribute of these features.
2. Length of values are not too long to fit in these polygons (You may further zoom into the polygon/ decreasing the size of the font).
Think Location
MichaelVolz
What is the source of data?
What desktop software and version are you using?
THayes2000
New Contributor II
