Points not appearing in the right place on ArcGIS Online map
292
10-13-2021 02:11 PM
SarahTruebe
New Contributor II
Hello,
I have an arcgis online map where the points are not appearing on the map in the correct place. For instance this screen grab shows a few labelled points. Zimmerman #3, for instance, is not plotting in the correct place.
Here are the coordinates; Zimmerman #3 should be further south than Zimmerman #1.
 LatLon
Zimmerman #1
32.44708-110.75820
Zimmerman #232.44777-110.75818
Zimmerman #332.44550-110.75666
Zimmerman #432.44870-110.75824
Zimmerman #532.44974-110.75691
This is likely an easy fix or a setting somewhere in the layer where I can make sure the points are appearing in the right place. Thanks for any help you can provide!
SarahTruebe
New Contributor II
Can anyone help with this please? We are seeing it in a couple of places on our organization's maps. Thanks!
