Hi all,
i enabled point clustering in a punctual layer in a Web Map and i correctly view this.
When i use the "Interactive Legend" mapping application related to this web map, i cannot see the point clustering but all as single points. The other layers are correctly filterable.
I'd like to show the punctual layer as point clustering in this application and not as simple points. How can i do this?
Thank you very much for your attention.
Piero
Solved! Go to Solution.
HI Piero,
Clustering isn't supported yet with the API that this was built with. Once the functionality is available, web maps with clustering enabled will appear clustered.
-Kelly
HI Piero,
-Kelly
Ok, thank you for the suggestion.
