Order of Geocoding Services in AGOL settings
522
06-28-2024 01:52 PM
clt_cabq
We have 3 geocoding services specified in our Geocoding section of the AGOL settings - does the order of these play a role in determining which is searched first and which provides results first when doing a search? I suspect it doesn't - I have a survey 123 app that will show results from these 3 services but would like one in particular to display first when a user is presented with candidates.
simoxu
by MVP Regular Contributor
To set a specific locator to return results from, supply the locator's item ID in the bind::esri:parameters column, for example, geocode=36ff9e8c13e042a58cfce4ad87f55d19
Please see the following document for details:
Geopoints—ArcGIS Survey123 | Documentation
clt_cabq
@simoxu thanks! i'll check to see if that will work!
