Is it posible to change the order of a features date field in arcgis online from month.dd.yyyy to dd.mm.yyyy ?
Solved! Go to Solution.
Hi Sebastian,
This is done by clicking the arrow next to the layer and choosing configure pop-up. Then select the date field and a menu will appear to change the format.
Thanks!
Hi Sebastian,
Thanks!
Ahh thanks! Now i see...
I'm so glad you posted this! I was needing to know how to make an attribute not editable and this did the trick! Thanks!
