Only Display Entries From Survey123 By Rolling Date Range (weekly)
1588
11-02-2023 07:15 AM
GregReinecke
Hello All,
Weekly I collect a respondents First and Last Name and the Date Created (hidden) for an event. The SignUp opens On Sunday and closes Thursday at noon).  Currently I clear the survey data every Saturday night and reset the Survey123 date range opening and closing for the coming week.
I really don't mind that I delete the data but also wouldn't mind keeping the data for later analysis BUT no matter what I just only want to see the current weeks data.
Currently I show the results in a table widget in Experience Builder.  Here is the survey link https://arcg.is/8T4q  and I have attached a simple .xlsx form.
I think this could be done a few ways supporting "IF an entry falls within the upcoming week THEN display it ELSE don't display it"
  1. Arcade expression in ArcGIS to create a field that adheres to the criteria
  2. Some sort of expression in ExB
  3. A calculated field in Survey123
  4. ModelBuilder script
Any suggestions or kickstarts would be very helpful. Thanks in advance,
GR
GregReinecke
This does what I want.
// This Arcade Expression assigns an attribute "Show" or "Hide" to a feature
// based on the day and time it was created. Also assigns "Hide" if not created
//during the current week.
// Get the current week for comparison to previous weeks
var currentDate = Now();
var currentWeek = Week(currentDate);
// Get the day of the week the feature was created
var dayOfWeek = Weekday($feature._date_time);
var dayOfWeekString = "";
if (dayOfWeek == 0) {dayOfWeekString = "Sunday"}
    else if (dayOfWeek == 1) {dayOfWeekString = "Monday"}
    else if (dayOfWeek == 2) {dayOfWeekString = "Tuesday"}
    else if (dayOfWeek == 3) {dayOfWeekString = "Wednesday"}
    else if (dayOfWeek == 4) {dayOfWeekString = "Thursday"}
    else if (dayOfWeek == 5) {dayOfWeekString = "Friday"}
    else  "Saturday"
// Get the time of day (_hour) the feature was created
var dateTimeField = $feature._date_time;
var _hour = Hour(dateTimeField);
// Get the time of day (_minute) the feature was created
var _minute = Text(Minute(dateTimeField), '00');
// Create _hour_minute
var _hour_minute = _hour + _minute
// Get the week the feature was created
var _week = Week($feature._date_time)
if (dayOfWeek == 0 && _week == currentWeek) {return 'Show'}
    else if (dayOfWeek == 1 && _week == currentWeek) {return 'Show'}
    else if (dayOfWeek == 2 && _week == currentWeek) {return 'Show'}
    else if (dayOfWeek == 3 && _week == currentWeek) {return 'Show'}
    else if (dayOfWeek == 4 && _hour_minute <= 1200 && _week == currentWeek) {return 'Show'}
    else return 'Hide'
GregReinecke
I started getting some code together. I have two features, one from a previous week and one from this week.
The feature last week generates a boolean "false" which makes sense based on the signup date.
The second point has a signup date of yesterday which I would think would prove out to be "true" but it doesn't.
Perhaps it could be due to the way the date is formatted.  Here is the code if anyone wants a look.
var now = Now();
var timeZoneOffsetHours = -5; // Eastern Time is UTC-5
// Adjust the current date and time to Eastern Time
var easternNow = DateAdd(now, timeZoneOffsetHours, "hour");
// Get the current day of the week and hour
var dayOfWeek = Weekday(easternNow);
var currentHour = Hour(easternNow);
// Define the time range for Sunday midnight to Thursday noon
var isWithinTimeRange = (dayOfWeek == 1 && currentHour >= 0) || // Sunday midnight
                       (dayOfWeek >= 2 && dayOfWeek <= 4); // Monday to Thursday
var isBeforeNoon = (dayOfWeek < 4) || (dayOfWeek == 4 && currentHour < 12); // Before Thursday noon
// Check if the feature's "_date_time" is within the specified time range
var featureCreationDate = $feature._date_time;
var isFeatureCreatedThisWeek = DateDiff(Week(easternNow), featureCreationDate, "day") >= 0;
return isWithinTimeRange && isBeforeNoon && isFeatureCreatedThisWeek;
GregReinecke
Still searching….     Is it possible Now() and
featureCreationDate
 actually have a different output format/structure so they always compare as false?  Thanks to all in advance.
GregReinecke
    else  "Saturday"
    else return 'Hide'
